LabWindows/CVI
SetCOmTime
Hi Roberto,
I'm trying to install the callback, but I it seems to me that it is not possible to put in OR with LWRS_RXFLAG in the eventMask the timeout condition, set with SetComTime () after OpenComConfig().
Just because I need to be advised if I don't receive anything within the timeout.
Can you help me again?
Message 11 of 13
(831 Views)
Yes, SetComTime will only work with variants of ComRd function and will not be fired in case of com callbacks. I suppose you can use a separate timer to handle the timeout event.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
Message 12 of 13
(824 Views)
The best final solution I found was to implement MyComRdTerm, as follows:
static int MyComRdTerm (int portNumber, char buffer[], size_t count, int terminationByte)
   int rec_num = 0;
   unsigned char single = (unsigned char)(terminationByte+1);
   int i=0;
   while ((single !=terminationByte)&&(i<count))
      rec_num = ComRd (portNumber, &single, 1); /* timeout is set after opening the serial com */
      if (rec_num == 1)
          buffer[i++] = single;
      else
         i=0;
         single = (unsigned char)terminationByte;
   return i;
Message 13 of 13
(820 Views)
