LabWindows/CVI
ServerTCPRead() Delay
Good Day, Sir
I am running a application in a while loop, my program acts as a TCP server, and receives Client data via ServerTCPRead() after getting a hardware trigger(SOT).
it is weird that when on line test the time elapsed~80ms in the while loop, but offline test without in while loop, the  time elapsed~5ms
while()
{//while loop
   If(sot==1)
   {//if
      T1=timer();
      dataSize = ServerTCPRead (g_hconversation, receiveBuf, dataSize, 1000);
      T2=timer();
   }//if
}//while loop
T2-T1 ~80ms(too long)
I have surf the similar question like:
https://forums.ni.com/t5/LabWindows-CVI/ServerTCPRead-always-takes-500ms-to-read-with-timeout-set-to...
could any one help me reduce the time elapsed to~5ms in a while loop?
thanks
(1,902 Views)
Accepted by 2axujgxr
If You are making stand alone application, then when compiling it use OpenMP .
Especially this part might solve Your problem.
Regards.
(1,793 Views)
