03-24-2007 10:10 PM
03-26-2007 07:01 AM
If you are just worried about CAPTURING the return, I would use the plain command
ComRd( port, buffer, count).
Set count (and your buffer size) sufficiently large enough to hold the largest possible response from your board. You can then parse it on your own.
If you are worried more about PARSING the response, I would need more information.
03-26-2007 11:58 AM
