‎01-31-2012 03:09 AM
Hi
I got a problem and please tell me it can be solved.
I see that there is a limit on how much a panel can scroll, is there a way to increase it or an update for Labwindows/CVI to make this greater?
What i got is alot of child panels about 400 each one has a height of 170. I display the beneath each other.
The problem is that i can only scroll to about child panel 192 then the rest are not there.
I need a way to display the child panels as above.
Is this possible?
‎01-31-2012 04:13 AM
Hi Shako,
just a guess: The maximum panel height is 32767 so I could imagine that also the 'virtual" panel size is limited to this number. You could check it by doing a calculation using your child panel heights times 192: is your child panel about 170 pixel high...?
‎01-31-2012 06:03 AM - edited ‎01-31-2012 06:05 AM
My child panels height are 170 pixels.
Is there a way to increase the parent panel virtual size to greater than 32767 ?
‎01-31-2012 06:34 AM
Hit the mark ![]()
How many child panels do you need to show simultaneously? Couldn't you just place them all on top of each other and then adjust visibility and / or z-plane position?
‎01-31-2012 06:47 AM
as many as possible.
I current do something similiar.
But i cant seem to get the look and feel for scrolling the same as the vertical scrolling panel.
