LabWindows/CVI
SQLite Implicit Linking
Hello everyone,
I wanted to test SQLite interface and, as usual, it's not so immediate in LabWindows but I've managed to create the .lib file and created an example using it.
I want to share it with you, attached x86 and x64 version, build on 3490100 release (3.49.1).
To build the .lib i've followed this guide:
How to build SQLite3 .lib file on Windows 10
    Download source from source
    For example: source https://www.sqlite.org/2023/sqlite-amalgamation-3430100.zip
    Download binary from binary
    For example: binary https://www.sqlite.org/2023/sqlite-dll-win64-x64-3430100.zip
    Extract both archives to the same directory
    Open Developer Command Prompt for VS 2017 by typing Developer Command in Windows Search
    Go to directory where you've extracted source code and binary files (via opened cmd)
    Run lib /DEF:sqlite3.def /OUT:sqlite3.lib /MACHINE:x64
to use my example just fix the "SQLite test.lnk" or "SQLite x64 test.lnk" to your folder path
Davide Vittorio G. - TLGB S.R.L.
Italian SW Developer
Message 1 of 1
(725 Views)
