LabWindows/CVI
SQL Toolkit DBFetchNext
Hello all,
I am trying to develope a program that uses SQL Toolkit on CVI 2010. I access to an Oracle database, using an ODBC connection.
I have a problem obtaining the data after a select query .
I am using DBNumberOfRecords to see how many records returns the query.
For getting data I use  DBBindColChar  function, and after DBFetchNext in while loop.
The problem is that value returned by  DBNumberOfRecords is different of values
returned in while loop with DBFetchNext. The correct value is the one returned by  DBNumberOfRecords  function.
I have attached a part of my source coude, where the problem occured.
Thanks in advandce for help!
(4,626 Views)
Anam,
What is the DBFetchNext in the while loop returning outputting?
Is it printing more or fewer times than the number of records returned by DBNumberOfRecords?
Kyle Mozdzyn
Applications Engineering
Kyle M.
(4,589 Views)
Number of records printed in while loop is lower than the one returned by DBNumberOfRecords.
In the loop, DBFetchNext returns 0, but at one point the value returned is -5, meaning that are no more records to print,
which is false.
Thanks a lot for your help!
(4,581 Views)
Accepted by Anam
Assuming that DBNumberOfRecords is truly returning the number of records in the select statement, could you answer a few questions for me:
1) Does the very first DBFetchNext print the first record you'd expect (assuming you know what the value of the first returned record should be)?
2) If you remove the call to DBNumberOfRecords does DBFetchNext print all of the records?
3) In your original code, try adding this line directly before your call to DBActivateSQL and let me know if you still have problems:
resCode = DBAllowFetchAnyDirection (dbHandle,TRUE);
Kevin B.
(4,492 Views)
Hello Kevin,
I found the response to my problem, while I was trying to respond to your questions:
1. DBFetchNext prints the first record.
2. If I removed DBNumberOfRecords, the number printed by DBFetchNext was correct!
3. I didn't try this solution, because I found the answer.
So thanks a lot for your time and suggestions, it was a great help!
(4,483 Views)
