LabWindows/CVI
SCPI commands R&S
Hello @xmouth,
Could you post a screenshot of your code as well as a screenshot of the error message that is displayed? These will be helpful as we explore the underlying cause of this issue.
Thanks!
Message 21 of 24
(1,492 Views)
NI IO error
Close Visa connection error.
Message 22 of 24
(1,485 Views)
Hello Xmouth,
 To follow up on Letitsnow, would you be able to post a screenshot of your code?
As he mentioned, that will help us connect the dots a little bit and maybe clarify a root cause.
Ali S.
Applications Engineering
Message 23 of 24
(1,470 Views)
You need to just write the fixing fre cmd and not wait for an answer... The instrument don't respond for this cmd, that's normal.
Message 24 of 24
(995 Views)
