LabWindows/CVI
Run distribuition with program open
I am using CVI 9.0.0
I built a distribuition for my program. At first  install everything worked perfectly.
Then after I relaunched the distribution without closing the program I  got the following error message:
"No software will be installed or removed."
 Now you can't install or remove the program because every time I have the same message. In Control panel (Applications install) I can't find my program.
To solve the problem I must remove all my program references in to Windows Registry.
Daniele
(3,473 Views)
Accepted by d.ghisla
The "No software will be installed or removed." message is standard when you run the installation kit a second time (although I'd prefer that it explcitly say that the software is already installed).
You app should be in the Add/Remove Programs list. Perhaps its name is not what you expected.  Sort by installation date to be sure.  Failing that, going back to a Restore Point might be your last non-manual option.
If you've partly removed the installation manually, running the installer again might repair the installation so you can see it in the Add/Remove list, and then remove it from there.
--Ian
(3,468 Views)
