07-01-2016 02:41 AM
Hello everybody,
I'm not sure if it's here that I would ask my question... Actually, when I run my code in labwindows to save parameters on network analyzer R&S ZNB8 I have an error :
Remote error 114 header suffix out of range calc1:par:meas'trc1','s11'
I thought it was just the variable TRC1 on labwindows whose doesn't the same TRC1 on network analyzer but when I changed this variable on labwindows the same error appears.
Anaël.
07-07-2016 02:32 AM
The value of a numeric suffix that is attached to a program mnemonic makes the header invalid. (A suffix is usually units, like Hz or DB). You can review on the header the suffix used on the program message unit.
07-07-2016 02:39 AM
I'm not sure that I understood everything but I tried to change the suffix (I believe it was that)
