LabWindows/CVI
Remote error on instrument
Hello everybody,
I'm not sure if it's here that I would ask my question... Actually, when I run my code in labwindows to save parameters on network analyzer R&S ZNB8 I have an error :
Remote error 114 header suffix out of range calc1:par:meas'trc1','s11'
I thought it was just the variable TRC1 on labwindows whose doesn't the same TRC1 on network analyzer but when I changed this variable on labwindows the same error appears.
Anaël.
(4,553 Views)
The value of a numeric suffix that is attached to a program mnemonic makes the header invalid. (A suffix is usually units, like Hz or DB). You can review on the header the suffix used on the program message unit.
(4,479 Views)
I'm not sure that I understood everything but I tried to change the suffix (I believe it was that)
(4,476 Views)
