03-01-2006 03:03 PM
03-02-2006
04:36 PM
- 最終編集日:
03-07-2025
02:00 PM
、編集者:
Content Cleaner
Hello kmc,
We discourage editing the project file manually to determine if a file's location is relative or not. The project file is a text file, so you should open it up in any text editor. The general syntax for making a file path relative is:
Path Is Rel = True
Path Rel To = "Project"
Path Rel Path = "../testfile.h"
Path = "/c/documents/testfile.h"
The valid values for the Path Rel To tag are:
In particular, the include path section can be found under [Include Paths].
By using ../ in the relative path, you can reference locations that aren't just subdirectories of the current directory of your project.
Hope that helps.
12-11-2007 03:15 PM
Hello Wendy, did this behavior change in CVI version 8.5 (the ability to hand-edit the [Include Paths] section in the project file)?
I used notepad to edit the paths to be relative, exactly as you had indicated. Worked fine.
Then later in the day I made a change to the project file (added some other non-source file to it).
Saved the project, then exited.
Re-opened the project later, and the relative paths were now absolute (went back to "Include Path 1 Is Rel = False").
So I did an experiment to prove my edits were being stepped on by CVI: I re-edited them to be relative path, was able to build project fine, made changes to contents of project via the CVI IDE, saved the project, viewed the edits I had made, and edits were back to absolute.
Am I doing something wrong here?
JB
12-11-2007 03:33 PM
To save some back and forth questions, here is exactly what I'm doing (I used just 1 include path to make it simple):
The project file starts out like this (before I edited it):
[Include Paths]
Include Path 1 = "/c/Workspace/dev/ATE/psdk/include"
I edit it manually to look like this (this project file lives in a folder next to the psdk folder, hence the use of the "../" notation):
[Include Paths]
Include Path 1 Is Rel = True
Include Path 1 Rel To = "Project"
Include Path 1 Rel Path = "../psdk/include"
Open CVI, and it understands the relative include paths in the project, and it builds fine, even after I discard all previous object files.
But if I modify the project file via the CVI IDE, it goes back the way it was before I edited it.
JB
12-12-2007 12:22 PM
12-12-2007 01:56 PM
Thanks for the quick reply, Luis.
I'm thinking that one work-around for me, for now, is to write a perl script to do these edits for me, and then manually invoke the script (using the "Tools>>Customize" mechanism) after a project file is saved from the CVI IDE. It's a PITA, but workable.
The purpose for me needing a feature like this is to assist live debugging on the target platform (the test stand), using the exact same libraries from the development platform (laptop), which are stored on a common network drive that is mounted to each platform the same way (relative to the project folder).
In my opinion, the less that any sort of "customizations" live in (or relative to) the CVI IDE, and the more they live in (or relative to) the actual files in the project(s), including all the project.prj files and the workspace.cws configuration file, then the easy it is for me to develop/debug on one system or another, knowing that I got the same exact libraries and project settings in the project(s) and in the workspace. Also, any edits to these libraries/settings become common to both platforms, even though I admit that the libraries are rarely edited unless it is necessary.
I believe this is true even for when a source code manager is used with the CVI 8.5 project(s). I am about to start using the Accurev SCM with CVI 8.5 this month for the first time. So far it looks compatible with it when I did a preliminary evaluation a couple of weeks ago, but I'll report back to this forum on how well I think it works after I've used it for a few more weeks/months.
JB
12-13-2007 02:48 PM
JB,
Since you're planning on sort of automating the editing of the project file, you might want to look at this example:
C:\Documents and Settings\All Users\Documents\National Instruments\CVI85\samples\dotnet\FileSystemWatcher
You
12-13-2007 02:48 PM
JB,
You can probably use some
12-13-2007 02:48 PM
JB,
You can probably use some of
12-13-2007 02:48 PM
JB,
