LabWindows/CVI
RegReadULong: values for dataFormat parameters
From the CVI 2009 SP1 help for RegReadULong() function:
dataFormat      int    This parameter specifies how the 32–bit integer is stored in the Registry. Typically, you will specify Little–Endian (Intel) format.
I don't know which values can have this parameter.
Are there any #defines for different formats?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(2,895 Views)
Accepted by vix
Hi Vix,
Sorry about the misleading help. This is actually just a boolean parameter. You pass zero if you want little-endian, and non-zero if you want big-endian.
Luis
(2,882 Views)
