LabWindows/CVI
Read TDMS from C++
hi all,
we are trying to read the TDMS property by using the TDM C DLL sample, copied the sample code below
// Reads the file
static int ReadFile (void)
int ddcError = 0, length;
DDCFileHandle file = 0;
char *property = 0;
// Read file name
ddcChk (DDC_OpenFileEx (FILE_PATH, "TDM", 1, &file));
ddcChk (DDC_GetFileStringPropertyLength (file, DDC_FILE_NAME, &length));
nullChk (property = malloc (length + 1));
ddcChk (DDC_GetFileProperty (file, DDC_FILE_NAME, property, length + 1));
printf ("File name property: %s\n", property);
free (property);
property = 0;
// Read file description, if present
if (DDC_GetFileStringPropertyLength (file, DDC_FILE_DESCRIPTION, &length) >= 0)
ddcChk (DDC_GetFileProperty (file, DDC_FILE_DESCRIPTION, property, length + 1));
printf ("File description property: %s\n", property);
free (property);
property = 0;
We are able to read the property length, but we need to read the value of wf_increment.
Any help on this is appreciable.
(4,875 Views)
This question has been posted also in the Diadem board where there already is a reply at the moment.
In the future try not to post the same question to different boards, or at least place some cross-reference in both boards so that threads are linked.
In this particular case, your mentioning of C++ confuses me: if you really want to use C++ then the CVI board is not the correct one since it uses standard ANSI C, not C++.
(4,865 Views)
Sorry for the wrong forum , thanks.
(4,843 Views)
