LabWindows/CVI
Problem with Shockwave Flash ActiveX control
Hi nqn827,
I've only looked at the problem a little bit and have only found that you can change the tab order of the ActiveX control by clicking on the ActiveX control itself. If you click on the little black box that contains the number next to the control, it doesn't seem to work for. Although this works for other controls. We will look into the issue and fix it as soon as possible but I can't provide any specific dates on when the next release will be which contains this fix.
Every release we include a list of bug fixes in the Readme as well as in an online tutorial so you can search there for the bug ID. You can also always call our support team and check on the status of the bug.
Best Regards,
Jonathan N.
Message 11 of 11
(888 Views)
