03-15-2006 03:35 PM
03-17-2006 11:26 AM
Yes, this seems to be a bug in CVI. The post-build step is running before the lib file is being written to disk. This will be fixed in the next patch or release of CVI. Thanks for reporting this to NI. I cannot think of any simple workarounds other than to copy the files manually after the build.
Mohan
03-21-2006 07:36 AM
03-21-2006 01:33 PM
10-28-2007 06:24 AM
I am using CVI 8.0.0
I have got the same problem. With - it seems - the same cause: when there is no previous-build output file the copy-command in a post-build-step-batch gives an error, and if there is a previous-build output file than it copies this old file.
Building twice is a work-around but I often forget it. Is there a patch for version 8.0.0 ?
Regards, Jos
10-29-2007 03:31 PM
10-29-2007 03:33 PM
10-30-2007 02:14 AM
Thanks all,
Jos
10-30-2007 10:10 AM
10-30-2007 07:12 PM
