 swati505
			swati505
			12-05-2005 03:34 PM
 RobertoBozzolo
			RobertoBozzolo
			12-06-2005 07:52 AM
Hi swati,
depending on the software installed on your machine, you may have installed the "date-time picker" activex control from Microsoft, which prompts the user with a calendar popup onto which to select the desired date.
As per every activex control, this control must be registered on the system in order for you to use it, and it must be installed on your customer system too when you deploy your application to him. Unfortunately I don't know exactly which MS program installed it on my machine (on which Office 2000 together with a bunch of other MS software is installed), so I cannot help you with reference to licensing problems.
Anyway, you may find this thread interesting as it explains how to install and register the control in case you don't find it on your machine.
Also look at this other thread as it explains hot to convert the time returned by the control to a format suitable for CVI to use it.
 AvnerG
			AvnerG
			12-06-2005 08:24 AM
 RobertoBozzolo
			RobertoBozzolo
			12-06-2005 08:36 AM
Strange indeed: on my machine it works regularly
Anyway, using the advanced search on this forum, look for "date time picker" on CVI board without time limits (linked threads are quite old: they are dated 2002): you should find a few links to follow two of them are linked on my first message.
Hope this helps
Roberto
 AvnerG
			AvnerG
			12-06-2005 10:07 AM
12-06-2005 12:50 PM
 RobertoBozzolo
			RobertoBozzolo
			12-07-2005 04:56 AM
