LabWindows/CVI
PeakDetector output arrays
PeakDetector function search an input array for peaks (or valleys) and returns 3 arrays
  • peakLocations
  • peakAmplitudes
  • peakSecondDerivatives
How are the peaks listed?
I mean: I think that every peak has the same position in all the 3 output arrays:
  • peak #1 - peakLocations[0], peakAmplitudes[0], peakSecondDerivatives[0]
  • peak #2 - peakLocations[1], peakAmplitudes[1], peakSecondDerivatives[1]
but how are the peaks listed?
Ordered by increasing peakLocations?
Ordered by increasing or decreasing peakAmplitudes?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(4,441 Views)
Could someone help with this question, please?
Vix
Using LV from 7
(4,365 Views)
Hi vix,
because of some limitations in the functionality (see here) I ended up with writing my own function... and as you can see from my linked post my tests date back six years, so I forgot the details you are asking for...
(4,361 Views)
Hi Wolfgang,
looking at your post I see you've been using ThresholdPeakDetector() - I didn't know this function exists.
On the other side, I've been using PeakDetector()
I don't know if the two functions behave somehow differently or if CVI2010 SP1 fixed the bug you found, but until now I haven't find any problem with PeakDetector().
Anyway, thanks to your suggestion I'll look deeper to avoid potential problems
Vix
Using LV from 7
(4,353 Views)
