LabWindows/CVI
Pass parameters custom popup
Hello.
I created a panel and want to show it like popup modal dialog.
My code is:
int panelHandle = LoadPanel(0, "Dialog.uir", PANEL);
if(panelHandle < 0)
return 0;
DisplayPanel(panelHandle);
RunUserInterface();
DiscardPanel(panelHandle);
I need to pass several parameters into the dialog. How can I do it?
Thank you.
(4,697 Views)
First of al, DisplayPanel does not show a panel as modal: use InstallPopup instead.
How are intending to customize the window?  Can you add some details?
(4,685 Views)
Hi Roberto, thank you for your answer.
There are  couple spinboxes and on dropdownlist on the popup (or panel), "OK" and "Cancel" buttons. So I want to pass couple double values and pointer to char (char*) to the dialog.
(4,657 Views)
Accepted by giker
Could a series of SetCtrlVal do what you want?
(4,653 Views)
Yes. It works. Thank you.
(4,650 Views)
You're welcome.
It looks like you are quite new to CVI: you should seriously consider reading the Getting Started manual; you'll find it linked in <cviDir>\bin folder, where <cviDir> is CVI installation folder.
(4,644 Views)
