LabWindows/CVI
Panel scaling
I have a question regarding Panel resizing. I have had a look at the example autoscaling.prj and the different scaling attributes. Is there a way to selectively scale panel contents on resize?. For example, is it possible to have a graph resize with panel resizing and keep all the buttons the same size and populated in proportion. A good example is Windows Media Player, on resizing the window, the viewing area changes but all the buttons and other stuff stays the same size and proportionally located.
Look forward to your reply.
Mike
(3,320 Views)
Mike,
What you describe is not available in the current version of CVI (7.0), but it will be available in the next version, which is currently in beta. If you're interested, you can sign up as a beta user in ni.com\beta, and we can then help you use this feature.
Luis
NI
(3,320 Views)
Hi Luis,
Thanks for the reply. I have registered as a beta user and await your acknowledgement.
Many Thanks
Mike
(3,320 Views)
