LabWindows/CVI
Obtaining pre-trigger data from triggered aquisition
I am trying to program an application to capture x samples before a trigger and y samples after a trigger.
I am looking at example programs using the DAQmx functions.
The "Acq-IntClk-AnlgStart.c" example captures a block of data occurring after a trigger event happens.  What is the best method to capture and read x samples prior to the trigger event in addition to the block of data after the trigger event?
(2,271 Views)
This community example using analog triggering but might be helpful to get you going.
https://forums.ni.com/t5/Example-Program-Drafts/DAQmx-Analog-triggering-by-software-under-LabWindows...
Applications Engineering
(2,245 Views)
