LabWindows/CVI
OPC UA architecture
maybe because i'm using the evaluation version.
i have to install the Full Developement System
calling_windows_sdk_functions
Davide Vittorio G. - TLGB S.R.L.
Italian SW Developer
Message 31 of 57
(5,143 Views)
I think you're right.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 32 of 57
(5,112 Views)
Tryed with a full version but still have the same problem... Smiley Sad
Message 33 of 57
(5,107 Views)
I didn't understand if Windows Kit has been installed during CVI installation by CVI installer itself or if it hasn't.
As I wrote, you can't manually download and install the Windows Kit from MS website and use it in CVI.
Does this help you?
Vix
Using LV from 7
Message 34 of 57
(5,105 Views)
i'm reinstalling CVI, which of this i have to chose?
Message 35 of 57
(5,099 Views)
The first one is enough.
Vix
Using LV from 7
Message 36 of 57
(5,096 Views)
nothing to do, still have the same problem.
are there any .fp or .lib to include?
Message 37 of 57
(5,094 Views)
Now we're sure the Windows Kit is installed properly.
I don't know how you are familiar with the usage of Windows Kit, but (as a general rule) every time you include a given .h file from the SDK you must add the relevant .lib to the project.
The .h contains the declarations only (i.e. data types, function prototypes, ...) but the lib contains the definitions (i.e. implementation).
To use OPC UA you need WS2_32.lib
Vix
Using LV from 7
Message 38 of 57
(5,087 Views)
build succeded! Smiley Very Happy
if you have time can you explain how to know which .lib i have to include when using a certain library?
i have used this
C:\Program Files (x86)\Windows Kits\8.1\Lib\winv6.3\um\x86\WS2_32.lib
Message 39 of 57
(5,084 Views)
Great!
I don't know if there is a quicker way but I do this:
  • When the linker gives me an error that function XXXXXXX() is not defined I search for the function name on https://docs.microsoft.com
  • in your case you had WSACleanup() not defined and you can find this page
  • At the bottom of the page you find Requirement section where you can see the Library item (which is ws2_32.lib)
  • Browse on your hard drive inside
    until you find the library. If you have more than one file, it depends on the architecure you're building for.
Please, open a different topic if you have other issues and/or questions
Vix
Using LV from 7
Message 40 of 57
(5,079 Views)
