LabWindows/CVI
NSV Async Read Callbacks
For some reason this mechanism is forbidden in LV but seems to be supported in CVI. It appears that
you can do an async read on a NSV and specify a callback function which gets invoked when the NSV value changes.
Does anyone know if it is possible to wrap this functionality up in a dll that would allow me to specify a NSV by URL
and a callback vi to execute.
(3,890 Views)
Hi Sachsm,
Firstly, there is a way to do this in LabVIEW, but it requires the DSC module: http://decibel.ni.com/content/docs/DOC-4375
If you don't have the DSC module then this probably can be done with CVI although it would be complicated.  What you would have to do is make a dll in CVI with the function to be called in LabVIEW.  This function will register the NSV callback and will poll for a value change variable which gets set by the NSV callback.  LabVIEW will then call the function and trigger a user event when the function returns.  However, it should be noted that at this point you are polling in CVI, and you might as well just create a loop in LabVIEW that is continually polling for the value change.
Hassan Atassi
Director, ni.com
(3,848 Views)
How does CVI create a NSV callback?  Is this an SVE API call?  Can it be done in LV without the DSC?  Don't get me wrong, I like and own the DSC toolkit, but I would like to better understand what is really going on under the hood in the SVE.  Somehow the DSC can register with the SVE for NSV events and then, I presume via a callback, generate a NSV type user event.  I currently use the DSC for doing this.  I then grab the generated User Event Refnum and register that with the Register Callback node for the purposes of having it call a LV vi that will send a notification.
(3,843 Views)
Hi sachsm,
You can check out the following example to see how you can potentially program NSV in CVI: http://decibel.ni.com/content/docs/DOC-3806
Hassan Atassi
Director, ni.com
(3,820 Views)
