LabWindows/CVI
NI MAX not detecting USB interface
Hello
I am using Tektronix PWS4323 Power supply with USB interface to windows XP machine.
I have problem with NI MAX 4.1, its not detecting power supply, but i can see it in VISA Interactive control as USB0::0x0699::0x0391::C020145::INSTR.
Any advise, should i upgrade NI MAX version ? please advise.
(2,754 Views)
Accepted by topic author hussainbasha
Hi hussainbasha,
Check out the link below with steps to help troubleshoot your issue with the USB device:
USB Device Missing in NI-MAX but Is Present in Windows Device Manager
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019La2SAE&l=en-US
Jiwhan S.
Technical Support Engineer
(2,644 Views)
Hello Jiwhan S
Thank you for your response,  it has helped me to understand the issue.
I tired uninstalling all the NI drivers and re-installed, after that it was able to detect the USB interface, later i was able to communicate.
Appreciate your help
Hussain
(2,630 Views)
