LabWindows/CVI
Multithreading rs232 in CVI
i'm doing in this way:
main thread -> numeric dial callback -> event val changed -> get lock -> set value to device -> release lock
second thread -> get lock -> read request -> read response -> release lock
Davide Vittorio G. - TLGB S.R.L.
Italian SW Developer
Message 11 of 17
(1,687 Views)
What happens if you change from val changed to commit event?
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
Message 12 of 17
(1,683 Views)
is the same.
now i have a lock that don't process event and the software freeze for a while and sometime doesn't change the value,
if i change the lock to process event the software don't freeze and sometime doesn't change the value
Message 13 of 17
(1,680 Views)
it's not working bad with the process event lock, it's happen rarely. i think i can keep it in this way
Message 14 of 17
(1,678 Views)
still have problem, i have this idea:
in the second thread create a switch case statement with this case:
request_value
wait_value
send_setpoint
in the main thread if i want to send the setpoint i set a flag and get in the right case
Message 15 of 17
(1,663 Views)
request_value
wait_value
send_setpoint
I don't understand exactly what you are saying with that: can you explain it a bit more detailed?
I would try changing the UI function this way:
Loop {
   TryToGetLock
      Exit if lock acquired
   ProcesSystemEvents
   Sleep (10)
Send command to device
Keep this function to the shortest possible.
This way the user interface remains responsive and you should be able to send the command to the remote device. It can be a problem if the user hits the dial too frequently.
Message 16 of 17
(1,644 Views)
tried your way, i have to test it more but seems ok.
i was thinking to do something like this
while(quit)
    switch(function)
        case request_read:
            comwrite
            go to wait_value function
            break;
        case wait_value:
            comread
            go to request_read
            break;
        case setpoint:
            break;
UI callback
    go to setpoint function
Message 17 of 17
(1,634 Views)
