LabWindows/CVI
Momentary switch
I'm new to CVI.
Any way to implement a push button with momentary action?
Only turn on when click on button, off upon release it.
Any example can I refer to?
(5,292 Views)
The "Command button" does just this.  It's momentary.
Or if you prefer, you could use any of the "Toggle buttons" or "Binary switches" and get this behavior by using a combination of the EVENT_LEFT_CLICK and EVENT_LEFT_CLICK_UP.  When you get the click up event, you could forcibly reset the switch control's position back to OFF.
(5,281 Views)
I followed using  EVENT_LEFT_CLICK and EVENT_LEFT_CLICK_UP to light a LED.
But when I press the toggle button, the button did not respond properly. Some lag occur & button only depress when click on its label. Only when double-clicking the button, it will then depress.
 switch (event)
  case EVENT_LEFT_CLICK:
   SetCtrlVal(panelHandle, PANEL_LED, 1);
   SetCtrlVal(panelHandle, PANEL_TOGGLEBUTTON_2, 1);
   break;
  case EVENT_LEFT_CLICK_UP:
   SetCtrlVal(panelHandle, PANEL_LED, 0);
   SetCtrlVal(panelHandle, PANEL_TOGGLEBUTTON_2, 0);
   break;
 return 0;
(5,272 Views)
Yes, that would be normal behavior for a Toggle button.  Toggles are not momentary: they keep their state.  But to get behavior you want, I've made you a sample project, with both Command and Toggle buttons:
(5,260 Views)
