LabWindows/CVI
'Mesa.dll could not be found' received from CVI 2010 installation
When I launch an executable that was installed from a distribution kit created with CVI 2010 (360), I get the message 'Mesa.dll could not be found'. But I can see that the file was installed at C:\Program Files\National Instruments\Shared\Mesa.  If I replace this file with an older mesa.dll from a previous version of CVI, my newly installed executable launches correctly.
Message 1 of 13
(19,335 Views)
Hi mrtqs,
I tried to reproduce this issue by building and installing a distribution kit using an example that calls Mesa.dll.  However, I did not receive any errors.  Can you give me some more information on what you were trying to build when you ran into this?
Hassan Atassi
Senior Group Manager, Digital Support
Message 2 of 13
(19,315 Views)
Hi Hassan:
I should have mentioned in my original message that in the 'Drivers & Components' tab of the 'Edit Installer' dialog box, I only select the following under the 'LabWindows/CVI Run-Time Engine':
1) Standard Run-Time
2) Analysis Support
3) ActiveX Container Support
4) Low-Level Support Driver
This configuration has always worked for me with previous CVI versions.
I'm building a 32-bit distribution kit in Windows XP SP3.
I am attempting to install on computers that have no other CVI files on them from previous installations.
Thanks for your help,
mrtqs
Message 3 of 13
(19,312 Views)
Hassan:
To answer your question...
I created a simple test program with a printf() statement and still get the message 'Mesa.dll could not be found' when I launch it.
Message 4 of 13
(19,318 Views)
Hi mrtqs,
What happens if you build one of the examples that references mesa.dll?  For example, the ledctrlarray example which is found under Building User Interfaces>>General in the example finder.
Hassan Atassi
Message 5 of 13
(19,295 Views)
Hi Hassan
Message 6 of 13
(19,285 Views)
Hassan:
When I first created the distribution kit for ledctrlarray, I left the default settings on the Drivers & Components tab in the Edit Installer dialog. The application installed and ran OK.
I uninstalled this and created a distribution kit a second time and only selected the following on the Drivers & Components tab (the same as my own program):
2) Analysis Support
This time I got the 'Mesa.dll could not be found' when I tried to launch ledctrlarray - although the mesa.dll file did get installed at C:\Program Files\National Instruments\Shared\Mesa.
I guess I need to figure out which additional item in the Drivers & Components list I need to start selecting in my distribution.
mrtqs
Message 7 of 13
(19,279 Views)
Hassan:
I've noticed that if I don't include the ActiveX Container Support in my distribution, my own application will install and launch OK (the ActiveX module is only needed for a small number of test systems I support). But if I include it and select [Check Module Dependencies] on the Drivers & Components tab then I get the attached message.
The [Check Module Dependencies] only returns successfully if I include everything in the Run-Time Engine block, or if I exclude ActiveX when selecting a subset of the runtime engine. I haven't had this problem with previous versions of CVI. I've tried it with 8.5.1 and 9.0.1.
mrtqs
Message 8 of 13
(19,260 Views)
Accepted by topic author mrtqs
Hi mrtqs,
While testing out this issue I ran into a similar problem.  From my understanding, the CVI Run-Time Engine will also install parts of the VS 2008 C++ Runtime.  Depending on what CVI Run Time options you choose to install a different part of the VS 2008 C++ runtime will be included in the installation.  It seems that Microsoft may have altered the VS 2008 C++ runtime for certain parts, but not others, which is what is causing the problem.  Hence there are a few options:
1. Install the full CVI runtime with the default settings
2. Leave out the ActiveX module if not needed
3. Install the VS 2008 C++ runtime separately on the deployment machine.
Hassan Atassi
Message 9 of 13
(19,235 Views)
I found exactly the same problem in a project where I include only "Standard Run-Time" item, so I read your suggestion:
  1. Install the full CVI runtime             ->              I don't like having to install unnecessary components
  2. leave out the ActiveX module         ->              not included
  3. install the VS C++ runtime on the deployment machine           ->            I downloaded and installed this package, and this fixes the issue, but the user has to launch another additional installer.
Could you attach to this discussion the right Merge Module (*.msm file) that I can add to my Distribution Kit? (as done for this old issue)
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 10 of 13
(18,552 Views)
