LabWindows/CVI
Match the data with the value of the color palette.
Nice to meet you. I'm a novice developer.
I want to express the size of this value in color when it is more than a certain value. For example, if there is a value of 1 to 100, I would like to express it with color interpolation from 1 (red) to 100 (blue).
I will attach a picture because my question might be difficult to understand.
I've looked up a lot of color examples, but I don't know how.
I need your help.
(1,786 Views)
Accepted by topic author Junho7780
You're trying to create an intensity gradient - similar to the one discussed in this thread https://stackoverflow.com/questions/7706339/grayscale-to-red-green-blue-matlab-jet-color-scale
Good to take a look at this example
https://forums.ni.com/t5/Example-Code/Gradient-Color-Ramp-Scrolling-using-Labview/ta-p/3524938
Santhosh
Soliton Technologies
(1,782 Views)
Oh, thank you so much.
That's the example I wanted! We can start the program now.
If you can run [Create Gradient Color Ramp.vi] on CVI, that's it! But I'm still not good enough. I need advice on how to get started!
(1,761 Views)
You cannot directly run a VI with CVI, but you could find some help in the examples that come with the product: here is the result of the example finder (Help >> Find Examples... menu function) on a search for "Intensity":
(1,743 Views)
