Overview
These VI demonstrate algorithms to generate color tables for LabVIEW color ramps.
Description
Use this Vi to create some color ramp. By using the rotate 1D array you could create some awesome gradient scrolling action.
In the first step the application creates colors shades and then creates movement by an array rotation .
Requirements
1. Open Scrolling Gradient Color Ramp LV2012 NI Verified
2. Set colors in color array
3. Run VI
4. Change speed
5. Try another colors combination
Top level VI Block Diagram
Thanks! Great code. Just used it to add some fancy effects to my GUI.
Kudos!
Awesome! I'm glad someone found it useful!
Very neat thanks for sharing. I had a need to generate a 2D picture with a gradient, so I took your output of an array of color boxes, and used the Draw Multiple Lines function, to draw a horizontal line for each color. There was some room for improvement, using the newer concatenating tunnel function, and removing the build array in Create Gradient Array.vi and just use the normal indexing tunnel.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
Brian Hoover wrote:
There was some room for improvement.
Considering that I was a 1-year LabVIEW user when I posted this, I'm sure there is quite a lot of room for improvement :-). Either way, I'm glad it was useful.
1 year or not, you accomplished what I was looking for with pretty minimal effort. I didn't have to write the code, I just did a search and this was the first complete result I found. That being said I did develop my own using .Net and a gradient brush but I like the G solution in this case.
I was looking for a way to color multiple lines in my XY graph in a gradient manner and found your tool very helpful, thanks!
