LabWindows/CVI
Local array initializations not recognized
This code generates a compile warning:
myRoutine()
    unsigned int localBuffer[8] = {0,0,0,0,0,0,0,0};
    if (condition)
        myVariable = localBuffer[1];
==>   warning: variable 'localBuffer[1]' is possibly uninitialized when used here
(4,410 Views)
Accepted by topic author richferrara
Hello richferrara!
I would like to ask you if you could provide more detailed information about this compiler warning you're seeing, since I wasn't able to reproduce the issue in CVI 2012 or CVI 2013. Could you please provide the following details?
  1. An exact code snippet of the program that you're using.
  2. Provide the released version of CVI.
  3. Mention the Compiler Warning Level (located at Options » Build Options » Configuration Options » Compiler Warnings) you were using and possibly other specific compiler options you changed from their default values.
Thank you!
(4,399 Views)
Sorry, this was my goof.  I didn't realize the code I was editing had another array with the same name defined locally in another routine.
(4,390 Views)
