LabWindows/CVI
Load an instrument
Hi guys.
I want to load my Rigol DSA1030A but I'm having some troubles. Can you explain me what is the procedure?The ip address of the instrument that is: USB0::0x0400::0x09C4::DSA1A143200160::INSTR
but when I click on load instrument it asks me for a *.fp file that I don't know where to find. On the Rigol page I find the IVI drivers that is an installer.
Can you help me?thank thank you
(4,433 Views)
Some first steps with useful links can be found here
The driver is found here
(4,431 Views)
Hi I have read already this page but without succes.
in particular I'm stucked here:
You can find instrument drivers for more than 5,000 instruments on the Instrument Driver Network. Look here to find an instrument driver for your particular instrument. If you find one, follow the procedure below to load it into CVI
In the IVI driver I don't find anything to load the driver on CVI since are all *.MNU file
(4,428 Views)
If the company claims it's an IVI driver for LabWindows (http://www.rigol.com/support/ivi/more.html) and it turns out it's not I would ask Rigol how to use their driver... Maybe they confused LabWindows with LabVIEW, who knows. At least their driver contains a VI...
(4,421 Views)
yep I saw that there is a VI and in fact I'm sure that with labview it works since I have configured it with MAX...so there is no way to configure it with CVI?
(4,418 Views)
