09-28-2021 05:41 AM
Ok really really thanks I will try and I will update you.
09-29-2021 01:45 AM
Hi ,guybrush_threepwood
I did that according to the following page which in the NI Help manual :
and I also make some small changes in my project in VS2015,such as renaming the .c file to .cpp file (After renaming it will run successfully).
My project in CVI is a small , simple project for testing integrating , it only has a button and a LED on the panel with a simple "switch on LED" function in code. So maybe it will be a bit more hard to deal with if the project is big and complicated.
10-28-2021
08:24 AM
- last edited on
11-01-2021
09:36 AM
by
NI_Community_Su
And by now ,I can successfully manipulate the labwindows/CVI panel by clicking the Qt widget panel . This means it's realizable to decorate the Labwindows project to many style freely .
( In my simple project I can click the Qt panel 's button to control the CVI panel 's LED. )
I am still trying on merging the CVI panel and the Qt panel together ,and leaving just ONE icon on the desktop's taskbar .
08-09-2022 09:48 AM
HI!
On the CVI platform, Use SQL condition range query (DBActivatesql (hdbc, "select * from testdata where testdate between '" + StartDate + "'and'" + enddate + "');) In the process, Why can't you extract the conditional string in the conditional string variable?. If the query condition is changed to a string constant, the previous closing record can be obtained normally.
08-09-2022 02:01 PM
What has this post to do with the argument of this discussion?
04-14-2025 03:52 AM
Hello Roberto,
Your suggestion has been on my mind for a long time.
But I haven't dared ask you.
It's a very cool and great display.
Perhaps you have a working example?
Thanks.
Patrick
04-14-2025 06:02 AM
Hello Patrick, there's no magic in that, just a little bit of creativity! And I can share it with you.
I have basically leveraged the transparent color to tailor the numerics and used two different indicators for integer and fractional digits with a custom function to write values to them.
Using transparent color can be tricky in case your panels have the Use Windows Visual Styles for Controls attribute enabled, since you cannot paint the frame in transparent on them. In this case I use a dummy panel without that attribute set and customize controls according to my needs. Customized controls can next be cut and pasted on the destination panel maintaining the transparency you set in the dummy panel. 😉
The two-dimensions indicator is basically built with two separate indicators put side-by-side:
Writing to this indicator is performed via this function:
/// HIFN ComplexInd ()
/// HIFN Show a value on a complex indicator (actually two
/// HIFN separate indicators for integer and fractional part)
/// HIPAR panel/Handle of the panel that hosts indicators
/// HIPAR ctlInt/Indicator used for integer part of the measure
/// HIPAR ctlDec/Indicator for fractional part
/// HIPAR val/Value to show
/// HIPAR nDec/Precision (number of decimals)
void CVIFUNC ComplexInd (int panel, int ctlInt, int ctlDec, double val, int nDec)
double intg, frac, scale = pow (10, nDec);
// Split integer and fractional parts
frac = modf (val, &intg); frac *= scale;
if (frac < 1.0e-4) frac = 0.0; // Avoid showing too small numbers
// Avoid showing (1+100 hundreds)
if (frac > scale - 1.0) { intg += 1.0; frac = 0.0; }
// Show values
SetCtrlAttribute (panel, ctlInt, ATTR_CTRL_VAL, intg);
SetCtrlAttribute (panel, ctlDec, ATTR_CTRL_VAL, frac);
return;
04-14-2025 07:27 AM
Hello Roberto,
Thank you very much.
You're always so helpful.
I suspected the solution, but I wanted to be sure.
The visual is so awesome 😎
Patrick.
