If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
05-20-2013 08:23 AM
I have a problem when I try to install Labwindows CVI 9 on Windows 7.
I had no problems so far, but now the installation doesn't work and the following message appears:
Do you help me please, it's very important and urgent.
Thank you.
Best Regards.
Karine.
05-21-2013
04:18 AM
- last edited on
05-14-2025
10:22 AM
by
Content Cleaner
I don't really understand the issue... you said that you have no problem when you install LabWindows CVI 2009 on Windows 7 - that's good!
And now you have an issue with an installation... with another software (I guess) ?
This error appears when you are installing an incompatible version or your toolkit/drivers/software with your actual OS.
As you are using Win 7, I suggest you to check the compatibility of what you want to install on your computer : https://www.ni.com/en/support/documentation/compatibility/09/national-instruments-product-compatibil...
Celine
National Instruments France
06-04-2013 08:27 AM
I worked on Labwindows CVI 9.0, then we recieved Labwindows CVI 2012 so I installed it but our software is developped with the Borland compiler, but it's not available in Labwindows CVI 2012.
So I uninstalled Labwindows CVI 2012 to reinstall Labwindows CVI 9.0, but the installation doesn't work, and the message above appears on my pc.
What should I do to reinstall Labwindows CVI 9.0 please?
Thank you.
Best Regards.
Karine.
