06-19-2012 12:57 AM
I developed Labview Gaussmeter Magnetometer with Hall Effect Sensor
https://decibel.ni.com/content/docs/DOC-22595. For the maximum, minimum and average gauss on the front panel, I set the default to zero and set zero as the defaul when I right clicked the indicators. I run the program once and get results. When I start it a second time, it starts at zero like it is supposed to do, but when I stop the program, it gives me the results of the first run. The only time the indicators are different is when the results are higher than the maximum gauss or lower than the maximum gauss. Thank you for any suggestions.
06-19-2012 01:13 AM
By accident you have chosen the wrong forum, this one here is for LabWindows/CVI You will get better response if you post it in the LabVIEW forum...
06-22-2012 01:45 AM
Thnak you
