LabWindows/CVI
Labview does not clear memory of indicators on front panel.
I developed Labview Gaussmeter Magnetometer with Hall Effect Sensor
https://decibel.ni.com/content/docs/DOC-22595.  For the maximum,  minimum and average gauss on the front panel, I set the default to zero and set zero as the defaul when I right clicked the indicators.  I run the program once and get results.  When I start it a second time, it starts at zero like it is supposed to do, but when I stop the program, it gives me the results of the first run.  The only time the indicators are different is when the results are higher than the maximum gauss or lower than the maximum gauss.  Thank you for any suggestions.
(3,293 Views)
By accident you have chosen the wrong forum, this one here is for LabWindows/CVI Smiley Wink You will get better response if you post it in the LabVIEW forum...
(3,291 Views)
Thnak you
(3,274 Views)
