‎01-23-2007 06:22 AM - edited ‎01-23-2007 06:22 AM
Message Edited by Debris466 on 01-23-2007 06:24 AM
‎01-24-2007 11:17 AM
‎02-05-2007 06:23 AM
Thank You John H. for your previous answer.
Indeed, i'm using the Legacy 1394 drivers for my cameras, so, as you said, they should be compatible with creating an installer. But now, I have the following problem. How do I bundle all of this drivers in one installer, so i don't have to install separatelly? Because I know how to use the "Create Distribution Kit", but I need support on how to include in this kit the drivers. Do i need to create an additional file group, or are there some advance options on how to include the drivers? Because if i leave it as it is, when i install on a target machine, the drivers are not there, so the application is not working.
Best regards
‎02-05-2007
09:01 AM
- last edited on
‎07-13-2025
09:19 PM
by
Content Cleaner
The ability to include drivers directly in your distribution package was added in version 8.0. If you are using an earlier version of CVI, you must install drivers separately to each target machine. If you like, you can download an evaluation version of CVI 8.1 to test it out.
Mert A.
