LabWindows/CVI
LabWindows/CVI myDAQ
Hello i need to know if somebody have used the ni myDAQ for audio sampling, I saw an example to do it but in labVIEW and I want to do it on labWindows/CVI, the problem here is that I try to use the DAQmxCreateAIMicrophoneChan and the channel audioInputLeft or audioInputRight are not supported...
can somebody help me?
(5,270 Views)
Accepted by diamoral22
This discussion has been posted in the Spanish forum too where have received some posts: see here.
If possible, additional contributions should follow there to avoid spreading the same argument over multiple boards.
(5,243 Views)
Just to have the answer in English as well:
You can use the CreateAIVoltageChan function, and just write audioinputLeft or audioinputRight as the physical channel to read data from the audio inputs in CVI.
Aldo H
Ingenieria de Aplicaciones
(5,227 Views)
Hi again, I don't know if you can help me with other thing, I want to get an audio signal on the myDAQ audio out signal , I'm filtering and processing this signal but now I want to hear it
do you know a way to do that? I'm working in lab windows cvi platform
I'm looking forward for your reply
thanks
(4,859 Views)
thanks
(4,839 Views)
