LabWindows/CVI
LabWindows 8.5.1 CopyFile Command
When trying to use the LabWindows 8.5.1 CopyFile command, I get the following error when compiling: Found 'pointer to char' expected a function.  I get this error even when using the 'Recall Function Panel' and selecting the file from within that area.  Any suggestions?
(4,725 Views)
You may have the <windows.h> definition of CopyFile hiding the <utility.h> definition.
I suppose you forgot to include <utility.h>
Nicolas
(4,720 Views)
I already have <utility.h> included and <windows.h> is not included.
Any other ideas?
(4,716 Views)
I still think you've got a problem related to inclusion or the preprocessor.
Could you please preprocess the source file  (Option/Preprocess source file) and search in the preprocessed file how your CopyFile has been processed.
If you can see CVI_CopyFile(arg1,arg2); the problem is not about preprocessing.
You could perhaps show us how you used CopyFile and how its arguments were declared
Nicolas
(4,710 Views)
Thanks for all the help, I found the problem.  I had inadvertantly named a variable 'CopyFile', which caused the problem.
Thanks Again.
Jim
(4,705 Views)
