キャンセル
次の結果を表示
次の代わりに検索
もしかして:
LabWindows 8.5.1 CopyFile Command
When trying to use the LabWindows 8.5.1 CopyFile command, I get the following error when compiling: Found 'pointer to char' expected a function.  I get this error even when using the 'Recall Function Panel' and selecting the file from within that area.  Any suggestions?
0 件の賞賛
メッセージ1/5
4,619件の閲覧回数
You may have the <windows.h> definition of CopyFile hiding the <utility.h> definition.
I suppose you forgot to include <utility.h>
Nicolas
0 件の賞賛
メッセージ2/5
4,614件の閲覧回数
I already have <utility.h> included and <windows.h> is not included.
Any other ideas?
0 件の賞賛
メッセージ3/5
4,610件の閲覧回数
I still think you've got a problem related to inclusion or the preprocessor.
Could you please preprocess the source file  (Option/Preprocess source file) and search in the preprocessed file how your CopyFile has been processed.
If you can see CVI_CopyFile(arg1,arg2); the problem is not about preprocessing.
You could perhaps show us how you used CopyFile and how its arguments were declared
Nicolas
0 件の賞賛
メッセージ4/5
4,604件の閲覧回数
Thanks for all the help, I found the problem.  I had inadvertantly named a variable 'CopyFile', which caused the problem.
Thanks Again.
Jim
0 件の賞賛
メッセージ5/5
4,599件の閲覧回数
