LabWindows/CVI
Is it possible to change the type of a Tree cell
I'm using LABWINDOW CVI 2015,
Starting from the xmlTree example, I have figured out that it is possible to set a cell in string:
SetTreeCellAttribute (panel, tree, ItemIndex, 0, ATTR_CELL_TYPE, VAL_CELL_RING);
In an other hand, the example event.prj show that the tree can be used with button, ring and combo_box (UI comming already formatted).
But my tests to put the cell programatically in an other type failed:
SetTreeCellAttribute (panel, tree, ItemIndex, 0, ATTR_CELL_TYPE, VAL_CELL_BUTTON); SetTreeCellAttribute (panel, tree, ItemIndex, 0, ATTR_CELL_TYPE, VAL_CELL_CHECK_BOX);
SetTreeCellAttribute (panel, tree, ItemIndex, 0, ATTR_CELL_TYPE, VAL_CELL_COMBO_BOX);
If someone has any idea?
Serge
(3,339 Views)
Accepted by Zergios26
That's because you cannot modify the cell type of column 0,and you should receive an error like attribute value not valid doing so: check the return value from the function. It is always a good habit to test for errors when a function does not what we expect it to do.
Even passing VAL_ALL_OBJECTS to operate on all cells in a row the first column remains unchanged.
(3,319 Views)
Thanks a lot, I was stucked on that.
Serge
(3,314 Views)
Hi again,
I was able to change the type of the tree cell following your instructions. But now I cant see how to change the value of a CHECK_BOX by program, how can I access the control inside the cell?
Any help would be great.
Serge
(3,270 Views)
Simply use Get/SetTreeCellAttribue with attribute ATTR_MARK_STATE.
(3,264 Views)
Thank you very much
(3,260 Views)
