LabWindows/CVI
Is CA_AllocMemory() Tracked in Resource Tracking?
I have been using the Resource Tracking option to track down memory leaks. But I recently noticed couple of  memory allocations using CA_AllocMemory() that were never freed. It didn't show up in Resource Tracking though. So I was wondering if it tracks only memory allocation using malloc/calloc or do I need to enable some option. I had the Options->Build Options->Debugging Level set to 'Extended'.
(4,240 Views)
Accepted by unnikrishnan
Hello unnikrishnan!
The bahaviour you are seing is expected, as the Resource Tracking window doesn't track individual memory allocations of CA_AllocMemory(). You can check the CVI help topic for Resource Tracking to read about the ActiveX objects that are tracked.
This link might help:
http://zone.ni.com/reference/en-XX/help/370051V-01/cvi/usermanual/resourcetrackingresources/
(4,207 Views)
Thank you...
(4,181 Views)
