LabWindows/CVI
Interger - Number of Digits
I have an interger which I do not want to exceed 2 digits.
Anything > XX should be returned as 2 digits or XX.
Example: 173 should be 73, 199 should be 99
Should I use a mask or modulus function ?
Diego
(3,364 Views)
for integer values you can use
    int i=199;
    int d;
    d=i%100;  //d2=99 ///two digits
    d=i%10;    //d2=9   //one digits
for float or double values you can use
    double d;
    double fint,frac;
    d=fmod(199.5,100); //d=99.5   two digits with fractional parts
  or if you not need fractional part of number
    frac=modf(d,&fint); //fint=99.0;frac=0.5
(3,355 Views)
OVR_CZ... the interger example worked like a charm.
Thanks very much
Diego
(3,335 Views)
