LabWindows/CVI
Instrument I/O Assistant
Thanks for the valuable information.
I will try this. If timing is a concern I could use a timer to check for new data?
'ComRdTerm' in the serial example has a count parameter, what if you don't know how many bytes there are to read?
Is there a max value?
Thanks.
Message 11 of 13
(1,242 Views)
ComRdTerm terminates either on termination characer received or on number of characters, whichever comes first.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
Message 12 of 13
(1,238 Views)
Accepted by topic author NI Nubie
Can you help with the attached file.
After I enter text and hit the <Enter> key I would like the data to appear in the recive window without having to use a button.
I an a little confused about the InstallComCallback and ComRdTerm commands and where they should go.
Thanks.
Message 13 of 13
(1,233 Views)
