01-14-2008 04:23 PM - edited 01-14-2008 04:25 PM
01-15-2008 08:26 AM
01-16-2008 07:47 AM
Jett,
I think you've misunderstood my problem/bug with the Application Builder. The icons that cause the errors (or rather produce the error messages, though may not be the real cause) are not mine. They are the icons/bmps that the CVI application uses in the file tree control of the application builder tool. Build >> Distributions >>Edit [name] ... <tab>Files . The problem does not happen all the time so I can still use the resource complier I just wanted to post the bug since it does cause a CVI to fail spectacularly when it happens. I do not yet know how to create the problem repeatably, I can find a series of steps that does it I will post it. I have seen this problem before on an XP machine, but I can't remember if I was running 8.1 or 8.5 Beta.
As for the file access errors, I have admin access, user access controls turned disabled, no uses access or file security what so ever. I my mind, the key point here is that CVI is the only application that seems to have any problems with file access on my machine. We also aren't taking about any sort of secure windows files or files in restricted directories that I could see causing problems. These are the source files that CVI has created. The are in a generic (non-user specific) folder on a local partition. The only other application that my ,machine that might access the files at the same time could be Google Apps indexing tool or Vista file indexing service. However, regardless of what else is running on my machine, I should never get a consistent file access error from CVI only... surely if there was a problem with Vista I would have similar problems in other applications. More likely I think CVI is incorrectly interpreting something as a file access error and/or not properly re-trying to save the file in persistent cases. In cases where the error is persistent, I can always open the file ANY other text editor. Again, this is not a fatal error. I can work with it, but wanted to post it so that it is known.
Greg
01-16-2008 09:30 AM
01-16-2008 02:08 PM - edited 01-16-2008 02:11 PM
03-04-2008 12:06 PM
03-04-2008 12:44 PM
03-05-2008 04:02 PM
05-29-2008 02:40 AM
Hi all,
I've the same problem on XP from version 8 or 8.1
Now I'm using CVI 8.5 without any luck, with the same bug.
05-29-2008 02:16 PM
