LabWindows/CVI
I want the ability to use/reformat a global string in multiple .c files. Error = Project Link Error: Multiple definitions for symbol...
Hi NI,
I usually find my solutions online but I'm struggling with this one. I've done this in an environment before but can't remember how I did it.
So I'm working on an ethernet comm interface. I have a TCP file where I'm using the NI tcp functions (TCP_DATAREADY, TCP_CONNECT, etc), and I have a telnet.c file where I've created simple send and recieve ethernet commands.
My issue right now is that I want to store the buffer I'm transmitting and the buffer I recieved for future use. Below is what I'm trying to accomplish.
*** memory.h file ****
extern char memTransmitString[256] = {0};
extern char memReadString[256] = {0};
*** telnet.c ***
#include "memory.h"
int SendTelnetCmd( bunch of stuff I need)
    // This sends the command
    error = ReadTelnetData (readBuffer);
*** tcp.c ***'
#include "memory.h"
case (event)
    TCP_DATAREADY:
    // code gets what I want to read and I store this string in "readBuffer"
    Fmt (memReadString, "%s", readBuffer);  // this is where I want to store what I read into memory so I can access this string in multiple files.
    break;
*** telnet.c ***
ReadTelnetData (char *readBuffer)
     // I trigger a TCP_DATAREADY event here ^^^^^ this is where I'll make the ethernet read and WANT to store read string into a global that I can access in multiple iles
     Fmt (readBuffer, "%s", memReadString; // this wll store the string from memory into my return string for this function.
So basically the compiler is gettnig mad that I'm reformatting memReadString (even tho technically I'm not reformatting i'm just transferring it back and forth between readBuffer).
The error I get is Project Link Error: Multiple definitions for symbol memReadString.
Pretty much the same thing for memTransmitString.
Can you help me fix this?
Justin
(4,199 Views)
Nevermind...
I fixed it by changing char memReadString[256] = {0}; in memory.h to static char memReadString[256] = {0};
(4,195 Views)
Did you test your code allready ? I think this "solution" has one side effect, you didn't thought of.  Declaring a variable outside a function body static means that it is local to the compilation unit.  A compilation unit is usually one preprocessed c file. So now you will have two different variables called memReadString in your code, one in telnet.c , one in tcp.c.  The right solution should be
declare in memory.h
extern char memReadString[ ]
and in one of telnet.c  or tcp.c  the variable definition
(4,146 Views)
