LabWindows/CVI
I've loaded the file but do not know how to open.
I'm trying out the program, wrote a document in the Cinergy Script Program. Once it was saved, I was told that I did not have the program to run the document. I downloaded a trial offer of NI Labwindows/CVI.
I tried to open the document, it was loaded but I can't determine the next step to open the document. It keeps saying that it is "already loaded". I wanted to edit it in Cingergy Script Program but now can not open it in that program.
Help!
Juliet
(2,994 Views)
Cinergy is an application from Mindstar Productions.  LabWindows CVI is a programming development environment.  Your problem doesn't sound like it's a CVI problem.
I'd suggest you uninstall then reinstall Cinergy.  Make sure you have the latest version.
http://www.mindstarprods.com/cinergy/ScriptEditor.html
Email your questions to support@MindstarProds.com
Good luck with your script!  Or should I say break a leg.
(2,968 Views)
