LabWindows/CVI
How to use network variable to transfer C structure data?
I found a CNVStruct in CNVDataType.
When calling "CNVCreateScalarDataValue" I always get a error message "Data type is invalid".
typedef struct TestType_t {
  int           float2[2];
  unsigned char Data[16];
} TestType;
 TestType    TestData = {{1,2},"23456"};
CNVCreateScalarDataValue(&data, CNVStruct, &TestData);
Does Network Variable only support primitive data types??
Can I transfer C structure data?
(3,485 Views)
Accepted by topic author VincentY
Hey Vincent -
You can send structure types, but you have to build them up.  Because your structure contains arrays, you have even more building to do.  It would look something like this:
CNVData dataStruct;
CNVData dataArrays[2];
int dims[] = {2};
TestType testData = { { 1, 2 }, "23456" };
CNVCreateArrayDataValue (&dataArrays[0], CNVInt32, testData.float2, 1, dims);
dims[0] = 16;
CNVCreateArrayDataValue (&dataArrays[1], CNVUInt8, testData.Data, 1, dims);
CNVCreateStructDataValue (&dataStruct, dataArrays, 2);
For more examples, check out the example 3DSimWriter.  Let me know if you have any questions!
NickB
(3,473 Views)
