LabWindows/CVI
How to unpack binary data from UDP port?
I have a device that is sending data to the computer via UDP.   I currently have python code that "unpacks" this data and turns it into something meaningful but I'm having trouble understanding how I can do this in cvi.  I can read the packed data using UDPRead but then in printing it out I just get a bunch of weird ascii and eventually I get a nul-terminated string and the program quits.  I guess I have to convert the data from binary to dec first but not exactly sure how. Are there any built-in cvi functions I can take advantage of?  I've attached the main python function that I've been using to accomplish this. Thanks!
(5,073 Views)
Hi Hillb,
There is a simple CVI shipping example that demonstrates how to do a UDP read.  I suggest that be the first place you look if you haven't looked at it already.
If you installed CVI in the default directory you can find this example here:
C:\Documents and Settings\All Users\Documents\National Instruments\CVI85\samples\udp\UDPReader.prj
I'll also suggest you take a look at this Developer Zone article:
"Building Networked Applications with the LabWindows™/CVI UDP Support Library"
http://zone.ni.com/devzone/cda/tut/p/id/6723
It explains a lot of the concepts and terminology CVI uses when doing UDP communication.
Let me know if you have more questions about these.
Kristen
(5,041 Views)
...and after you have read your message into an unsigned char variable (e.g. "msg[ ]") you can simply do the following to transform the message into meaningful values:
     int  cmdid, isData, result;
       cmdid = (msg[0] << 😎 + msg[1];
       isData = msg[2];
       result = (msg[3] << 😎 + msg[4];
(5,029 Views)
Thanks Roberto! I'll give it a try.  I already have UDPRead working
(5,027 Views)
hillb wrote:
"I guess I have to convert the data from binary to dec first but not exactly sure how"
computer science course, lesson 1: A VARIABLE STORES A NUMBER, NOT THE REPRESENTATION OF A NUMBER !
e.g.:
int a = 8;
'a' contains the value which is commonly represented by humans as 8 in decimal. but it is also 1000 in binary or 10 in octal of 8 in hexadecimal. thus, all those tests are true without performiong any 'conversion' on the variable:
a == 8      // decimal
a == 0x8  // hexadecimal
a == 010  // octal
(food for thought: decimal is a weird representation used by humans only because they have 10 fingers. imagine if we had 4 fingers on one hand, and 3 on the other)
(5,013 Views)
