LabWindows/CVI
How to truncate a file?
I want to truncate a file without having to copy it in a temporary file.
I try to put the EOF character in my file or something like that without succes.
I found the SetEndOfFile() function in the basicsdk library but it doesn't seem to work, it returns 0.
Do you have any idea?
Here is my code with my try in comment:
            TrouveTemps = False;
            FichierTemp = fopen(CheminTemp,"r+");
            while(fgets (LigneTemp, sizeof(LigneTemp)-1, FichierTemp)!=NULL && !TrouveTemps )
                pFinHeure = strstr(LigneTemp,"\t");
                if(pFinHeure != NULL)
                    *pFinHeure = 0;
                    DureeEnreg = ChaineToHeure(LigneTemp);
                    if(DureeTotal<DureeEnreg)
                        TrouveTemps = True;
            j=4;
            //fwrite (&j, 1, 1, FichierTemp);
            //fputc(4,FichierTemp);
            //putchar(EOF);
            j = SetEndOfFile(FichierTemp);
            fclose(FichierTemp);
Yop!
DanY
Message 1 of 9
(6,793 Views)
HI!
   I've checked, but found nothing.... putting EOF character does not solve, and you don't have a "truncate file from here" function.  The only way to truncate a file is deleting all data.
   So, I think you're forced to use a temporary file.....
   I'm sorry I didn't find a solution, if someone else has one....
   Bye!
graziano
Message 2 of 9
(6,783 Views)
But what about that SetEndOfFile() function from windows?
Has someone already used it with success?
Yop!
DanY
Message 3 of 9
(6,775 Views)
Well, SetEndOfFile does behave correctly on files opened with windows API functions. Look at this function that selects a file and truncates it to 256 bytes.
int CVICALLBACK TruncateFile (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
 char file[MAX_PATHNAME_LEN], msg[512];
 DWORD error = 0;
 HANDLE fH = NULL;
 if (event != EVENT_COMMIT) return 0;
 if (FileSelectPopup ("", "*.*", "", "File to truncate",
   VAL_SELECT_BUTTON, 0, 0, 1, 0, file) == VAL_NO_FILE_SELECTED)
  return 0;
 //HANDLE CreateFile (
 // LPCTSTR lpFileName,                         // file name
 // DWORD dwDesiredAccess,                      // access mode
 // DWORD dwShareMode,                          // share mode
 // LPSECURITY_ATTRIBUTES lpSecurityAttributes, // SD
 // DWORD dwCreationDisposition,                // how to create
 // DWORD dwFlagsAndAttributes,                 // file attributes
 // HANDLE hTemplateFile                        // handle to template file
 fH = CreateFile (file, GENERIC_WRITE, 0, NULL, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, NULL);
 if (fH == INVALID_HANDLE_VALUE) {
  //DWORD GetLastError (VOID);
  error = GetLastError ();
  goto Error;
 //DWORD SetFilePointer (
 // HANDLE hFile,                // handle to file
 // LONG lDistanceToMove,        // bytes to move pointer
 // PLONG lpDistanceToMoveHigh,  // bytes to move pointer
 // DWORD dwMoveMethod           // starting point
 if (SetFilePointer (fH, 0xff, NULL, FILE_BEGIN) == INVALID_SET_FILE_POINTER) {
  goto Error;
 //BOOL SetEndOfFile (
 // HANDLE hFile   // handle to file
 if (!SetEndOfFile (fH)) {
Error:
 if (fH != INVALID_HANDLE_VALUE) CloseHandle(fH);
 if (error) {
  memset (msg, 0, 512);
  //DWORD FormatMessage(
  // DWORD dwFlags,      // source and processing options
  // LPCVOID lpSource,   // message source
  // DWORD dwMessageId,  // message identifier
  // DWORD dwLanguageId, // language identifier
  // LPTSTR lpBuffer,    // message buffer
  // DWORD nSize,        // maximum size of message buffer
  // va_list *Arguments  // array of message inserts
  FormatMessage (FORMAT_MESSAGE_FROM_SYSTEM, NULL, error, 0, msg, 511, NULL);
  if (!strlen (msg)) sprintf (msg, "Error %d", error);
  MessagePopup ("Error", msg);
 return 0;
Message Edited by Roberto Bozzolo on 04-07-2006 03:36 PM
Message 4 of 9
(6,771 Views)
Great!
  I learnt something more!  Smiley Very Happy
   Anyway, this is a windows API function, I always try to manage with ANSI-C functions, and, when possible, LabWindows' libraries functions......
   By the way, why does open() function is not  ANSI-C standard??????????? Smiley Mad  (I'm asking to NI people....).
   Bye! And have a great HolyWeek!
graziano
Message 5 of 9
(6,762 Views)
Thank you very much, i'll see if I change of library
Have a nice WE.
Yop!
DanY
Message 6 of 9
(6,756 Views)
Graziano,
That's a question that you'll have to ask the ANSI folks, not NI Smiley Tongue
My understanding is that those low-level IO functions are part of the POSIX standard. CVI still includes them in our C library for convenience, since they're fairly common. However, they're not part of the ANSI specification.
Luis
NI
Message 7 of 9
(6,747 Views)
Hi LuisG,
   Thanks for your interest!
Bye!
graziano
Message 8 of 9
(6,740 Views)
I was quite happy at your post.
It works well.
I open the file with function OpenFile as a CVI function.
In order to use the CreateFile Function I needed to
set the parameter FILE SHARE_WRITE in the CreateFile function.
Then the file was created by a CVI function and closed and reopend
with the CreateFile function.
Thanks a lot for your post.
Yours sincerely
Othmar Widmer
Message 9 of 9
(5,130 Views)
