LabWindows/CVI
How to plot a histogram graphic using data acquisited
I would like to know how could i plot a histogram graphic using data acquisited. I have a device data acquisition and I have 8K samples per second. I need to show the first ten data at the histogram graphic.
For example:
10 volts (1sec), 12 volts(2sec), 14 volts(3sec).....these datas i put in an array
Could you give me some example about it?
(4,581 Views)
CVI ships with two examples that plot histograms: mode.prj and tempsys.prj.
In CVI 9.01, go to Help >> Find Examples, then click on the search tab and enter histogram.
In CVI 6.0, go to C:\Program Files\National Instruments\MeasurementStudio\CVI\samples, and search for mode.prj or tempsys.prj
(4,578 Views)
