LabWindows/CVI
How to hide graph cursors without setting number of cursors to zero
I am using labwindows/cvi 8 and I would like to be able to hide and unhide cursors on a graph while retaining their color and position.  I have found that I can use the number of cursors attribute for the graph, if I set it to zero it removes the cursors.  Then if I turn around and set it to the original number of cursors, say 4, then I am forced to reprogram all of the attributes for the cursors such as position, color, etc.  Isn't there a simple way to just hide the cursors.  I found a enable / disable attribute, but that does not hide the cursors.
Thanks in advance for any help
Darren
(3,115 Views)
Hello Darren,
I think there are two ways to do this:
1: use SetCursorAttribute with attribute ATTR_CURSOR_COLOR and value VAL_TRANSPARENT.
2: use SetCursorAttribute  twice. Once with attribute ATTR_CROSS_HAIR_STYLE and value VAL_NO_CROSS, and once with attribute ATTR_CURSOR_POINT_STYLE and value VAL_NO_POINT.
I don't know if there is any other, more decent way to do this...
(3,111 Views)
